Discuss what do these 380v wiring colours mean, I want to use with a 220v vfd. it may have had speed control in the UK Electrical Forum area at ElectriciansForums.net
No problem, looking into these things is all part of the fun. I hope they can find a convenient solution for you. The guys at the rewind place might be amused to read this thread too!
On the bench here in the workshop I'd have done the swap-around of the winding ends and run it up on a 3-phase variac with a lamp limiter, which would soon prove whether the mod was correct and prevent damage if one winding was out of phase etc. But I appreciate that from where you are, especially with no 3-phase to test with, it's a bit of a challenge and a leap of faith.
Earth it the same as you would any other metal cased appliance - just make sure the earth connection in the mains lead and plug is sound. At the equipment end, make sure each item with mains connection has it's case earthed.
thank you!
Thanks a million for your help here and on the other post, this project has opened my eyes and head up to what is doable and the need to ask questions, I really did want to learn a bit more about motors, this was great and amazing to see how complex it is and see whizz kids in action :) i studied some electronics theory years ago, it was never my strong point.
Speedystu: many of us are keen to know how this thread was resolved - or maybe only me! :)
Hey, I costed all options to get the power feed working, it was not economical for me to proceed, I bought I knowing it was a risk but thanks to the forum I was able to see what was involved. I have to say I really enjoyed learning from you all. I am using the knowledge gained to make really smart El trical decisions going forward . For now I need to stick to 220 v and buy machinery at that. Thanks again!
Hi again, SUCCESS, I have purchased a (think 9hp) diesel generator for a good price, it is key start, it's a few years old and needs some tidying up and is a bit noisy but is for a rural workshop. It has two 110 and two 220 sockets and has another socket pictured below, is some one able to help identify what output the other socket it is and if I need to test it to check what's coming out. It may be an old connecting pin ( I'm not sure) in my workshop, I need to use some motors ( including a custom power feed, I want to know what size and phase will work with this. It would be great to hear some opinions. Thanks all! Hope everyone is keeping safe .
Hi All
Hope things are going ok at this time.
I have come across a powerfeed for woodworking but its a 3 ph unit, I only have 220v 1ph, can this motor be tweaked or be used with a vfd to make it run and still do its normal job?
Please see the motor plate below, thank you!!!Screenshot_20201124-100434.png
Unfortunately, No it can't.
It is a 2 speed 400v motor.
if it were a dual voltage motor the nameplate voltage would read something like 230/400 v
I think it's the same deal as the previous motor. 400V pole-changing configuration will only run on 400V as supplied, but could in theory be internally modified to a 230V 2-pole. Having chosen not to go that way with the first one I'm not going to suggest it here. I've no experience of running VFDs through transformers, but is that an option?
Reply to what do these 380v wiring colours mean, I want to use with a 220v vfd. it may have had speed control in the UK Electrical Forum area at ElectriciansForums.net
Posted this to the DIY section since I'm not a business or employee in this matter but it feels more appropriate (and might actually get...
Hello, DIYer and first time poster here. Recently bought a house built in 1925, and am gradually working through adding and replacing the wiring...
Hi All, A mate of mine recently acquired a rather nice wood turning lathe they'd like to get running out in their workshop. However he admits his...
Hi everyone, I want to install a wifi switch in my room but the problem is I am not very informed in electrical wiring subject so would appreciate...
M
It's not car related but is a 12vdc porject, so hope someone can be of help to me on this project I’m a bit of an amateur photographer when it...
mollydog
M
