Discuss What d'ya reckon? in the Australia area at ElectriciansForums.net
drcat
10 Kw Shower installation, CU 2 floors down and 4 meters back. Approx 10mm2 cable run of 12 meters. Can I spur from lighting circuit in attic above airing cupboard into separate RCD enclosure fixed in airing cupboard to reduce wiring run or do I run fully to CU and install RCBO (if poss)or fix a separate shower RCD enclosure there?
yeah i think this chap was having a friday evening laugh!! he's worded stuff as a sparky would! sept for the lighting circuit thing obviousyl
This is what happens when you put a shower through lighting cable fed from the ring. It works once (briefly) and then you get your house rewired :)
1.5mm 6242Y from ring
Chock strip to connect the 6242Y from ring to 6243Y 1.5mm to shower. Got a bit warm eh;)
Where shower used to be.
Service Head -> 2 tails -> Meter -> 2 tails -> Isolation switch (Already in place) -> 2 tails (25mm2)-> DP Henley -> four tails (25mm2) -> existing CU & Separate Shower CU (63A 30mA RCD, 50A MCB) and I think 16mm Earth from Shower CU to Existing CU. I'm buying the stuff in, mate supposed to be fitting 'em, he's a spark. I just wanted to know if there was a better / easier way really (and I was trying to show off), hadn't thought properly 'bout the light circuit spur thing, thinner cable and lower rated MCB an all that - I'm a chippie see. If I can't nail it or screw it i'm stumped! I did do 2 yrs of 'leccy apprenticeship 20 yrs ago... shh! - but didn't learn 'owt except for mitring trunking, chasing walls, Lifting / replacing loft insulation and making lots of tea. As it happens, the guy I was apprenticed to got electrocuted and killed on site. I'm not a fan of electric, I don't know how you guys work 'Live'. Bloody stupid if you ask me. Though I'm OK spurring the odd socket here and there but thats about it. When I told sparky mate what I posted, he pi553d himself laughin'
Oh Aye - One more thing - I've been advised that Main Earth Bonding should be upgraded to 10mm as there is more load (I have a 60 amp service head) with this shower but sparky mate reckons it'll be OK as is... Whats the general concensus? Main earth bonding refit would require power cut by DNO yes? Would the DNO be the ones who upgraded the Main Earth Bonding? I have a TN-C-S system so would PEN conductor need upgrading also? Cheers!
well to answer the question, you would need to clarify, are you talking about earthing or bonding - there is no such thing as earth bonding;)
are you talikng about the emain earth or the bonding going to your incoming gas/water?
If you have a mate that is a electrician why are you asking these questions as he is the one who is going to notify this work through his scheme provider or LABC and he should be advising you on what to buy as he will be responsible.
Not being funny but just confused:)
I'm interested, that's all, reading this forum has piqued my curiosity. Something new to learn. I like knowing what is what.. simple as that.
Reply to What d'ya reckon? in the Australia area at ElectriciansForums.net
Recently visited a new build to do a very minor job and spotted a few dodgy looking items so Client asked me to do an EICR. Following items I...
I'm planning a replacement for my existing domestic CU and would like to have it sanity checked before I get an electrician involved. The main...
4K
Doing some testing today on a Wet Room installation. Fed from its own small CU. And consists of 2 x seperate 50A (for 10.5kw shower) circuits...
I have had a kitchen extesion built on an old property (c.1810), which has an unusual consumer unit situation. Part of the property has only a...
