Discuss What fuse to use 2 pin to 3 pin plug in the DIY Electrical Advice area at ElectriciansForums.net
Ashley
I have bought myself a compressor for airbrushing and it came with a 2 pin German plug on the plug it says 16A250v so i initially thought cut it off and stick uk 13 A plug on. however, i am now questioning this as the compressor is 1/6hp 220-240v/50HZ which is making me think a 3A or 5A fuse would be ok.
1/6 hp (0.17hp) is very small and drawing very little current. Not sure on the start-up current of it. Will have to fit a slow-blow fuse.
Out of interest, what size cable has come with the compressor. Does the compressor have it's own fuse? (Not the one in the plug)
Doesn't this give you a clue?
I'd put a 13A fuse in there. a smaller fuse may pop due to inrush current when compressor starts up.
its a standard twin and earth, also i tried only for about 10 seconds powering it up in a shaver plug converter with a 1a fuse in and it worked
There are many many different types and sizes of twin and earth. Often the size is written on the flex. But, if it works with a 1A fuse, then put a 3A in the plug. It’ll be fine.
Can you show a pic of the German plug because it may require an earth connection and a shaver adapter will not provide one.
Question? what does the fuse in a plug top protect?
The cable, of course. We don't know the size of the cable, I did ask..
PS, the fuse goes in the bottom of the plug, not the top:p
He said a standard Twin and Earth lol, must be a 16mm2 then lol
does it? lol
So did I, in post #2.
I thought that "standard twin and earth" wired into a BS 1363 plug was frownded upon.
Okay Okay, roll over, I will rub your belly lol
It is highly unlikely to be T&E if the cord came with the appliance, OP error.
Yaaaaaay... will you scratch my back as well???
Hold on.... that sound rude....
  • Funny
Reactions: MDJ
Reply to What fuse to use 2 pin to 3 pin plug in the DIY Electrical Advice area at ElectriciansForums.net
I have a question which is confusing me and I cannot find a definitive answer and I hope someone can help. So I have a PC and Monitor and I have...
Hi, leading on from my question the other day about running the 3 phase compressor off my 8.5kW generator I have since got my hands on a 240v to 3...
Hello, I'm seeking some advice on an overheating plug adaptor please. Complete amateur so please forgive any errors in calcs / assumptions /...
Hi all, Hoping someone can shed some light on this, i have purchased a surge protector and it will not fit the power cables i plan on using. I...
Hi, I Bought a 32A EV Charger, it comes with a CEE wall plug. I need to use it with a 60A range recepticle which I use to plug in my welder. So...
