What is the meter used for and why do you wish to change the value?
The meter you show will probably be factory calibrated and will show how much energy passes through it during use, we need to know why you wish to change this value before advice is offered on the matter, altering the calibrated setup would mean the meter would not function as designed and you would end up with a readout that doesn't match actual energy consumed.
