Discuss What is my Earthing Arrangement? in the DIY Electrical Advice area at ElectriciansForums.net
Deleted member 123470
Hi,
I'm currently installing a new consumer unit and I cannot clearly identify my earthing arrangement.
(image attached)
I am leaning towards TN-S but could potentially be TN-C-S as it is a unit installed in the 70's and doesn't match the drawings in the OSG. Any expert advice would greatly appreciated.
If the earth is combined with head then a tncs or the earth combined in swa then a tns if no earth present then TT .can you see a swa cable .if not then a tncs .
The earthing type or lack of information can only be provided by the supplier
You need to assume that you have to provide your own means of earthing unless or until the supplier says otherwise,best go on the phone and start asking
It is a concern you are replacing a consumer unit and using pictures from the OSG to try and determine the earthing system.
Don’t think it’s a tns
Have you done a Ze at the old fusebox by any chance ?
Is that black lead apparently coming from the lower left of the head an earthing conductor?
Yes it is, it feeds directly into a MET then to the current consumer unit.
[automerge]1572685823[/automerge]
Not yet, will be the first thing I do before replacing the CU to make sure it's within 0.35 ohms. Just trying to determine the arrangement before doing the paperwork so I can challenge the supplier if their is a problem. Its a very old system an falling to bits
my bet is that it's sweated onto the incoming cable sheath, under that plastic below the fuse.. therefore TN-S.
That's what I was thinking, cheers. I think I'm going to ring the supplier just to be certain.
Tganks
Test pefc and pssc and compare results ?
Your profile lists you as a diyer which is very concerning.
I'm Part P qualified and have a lot of experience with basic electrical work. so have the necessary knowledge to make these upgrades. DIYer was the best fit option. Just got caught off guard by this old cut out. Appreciate the concern buddy
maybe you should edit your profile. if you've done a short course and joined a scheme, then Domestic Installer would be appropriate. If you don't have that option, I'm sure Dan could make it happen.
Reply to What is my Earthing Arrangement? in the DIY Electrical Advice area at ElectriciansForums.net
Hi all, I am at odds on whether RCD protection is required on an SWA of 14 metres, clipped direct under flooring direct from CU to an exterior...
The earthing arrangement where the hot tub will be installed is formed in the TN-C-S system. I want to install the sub-main distribution circuit...
Hi, I'm interested in a house built around the 1980's in Northern Ireland. I took a few photos of the consumer unit etc. which is situated in the...
Hi, I have received conflicting advice about Main Isolator Switches and would appreciate forum member's help to plan a way ahead. Looking to the...
Deleted member 155212
