Discuss what is needed for certification ? in the UK Electrical Forum area at ElectriciansForums.net
Eicr's carried out by another firm,C1's reported (missing blanks in CU) and C2's reported top of CU not rated to IP2X . and a faulty socket. The reports say it is unsatisfactory.
I have replaced the blanks and sealed the CU's with intumescent sealant and fitted a new socket can I juat attach a note to the report stating the work has been done ? seems a bit overkill for minor works certs or EIC
If you've fitted a new socket, that will need a minor works certificate if it's an addition to an existing circuit or an EIC if it's a new circuit, but for the fixes I would simply write a report stating what had been done to address the issues and attach some pictures showing the before and after.
Ive just re-read your reply the new socket is replacing a faulty one,like for like
Reply to what is needed for certification ? in the UK Electrical Forum area at ElectriciansForums.net
Hi Everyone, This is my last question/post for tonight, promise. Please can I ask for a little advice on certificates as I am now questioning...
Hi guys, need a bit of advice, EICR was completed on the property which needed a new consumer unit and a few other bits like broken sockets and...
As above ,does any of the following work require a minor work cert, changing MCB's, changing sockets, fitting CU blanks, filling CU holes with...
Private tenant since 2011. First ever eicr February 23 informed via text it failed by text from electric secretary arranging appointment for...
Hi, I'm looking for some advice please. I'm not an electrician but have employed a registered qualified one to do some work for me and want to...
