Discuss What is the equivalent resistance of this network in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
T
turbomen
Two resistors, R1 and R2 are connected in parallel. R1 is 2kW, R2 is 4kW. What is the equivalent resistance of this network (answer rounded to nearest whole Ohm):
Could you tell me how can you get the answer?
Can I do in this way:-
1/r = 1/2k+1/4k
1/r = 2/4k+1/4k
1/r= 3/4k
r=1333
But could you mind tell me about the formula? Because I do not learn the formula in before.
Cheers,
You put the decimal point in the wrong place, the answer is 1.33 but you got it.
The formula is the method for calculating resistance in parallel, I don't know what else to say.
Reply to What is the equivalent resistance of this network in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
I have been going round in circles with this question. I just cant seem to get an answer remotely close to the options. Continuity of a ring...
Hey there, Sorry I’ve just joined up. I’m a qualified electrician/Electrical engineer. Recently sat my 2391-52. My question is I had a fault...
Over the last few days, I have stumbled across a number of threads that seem to point to a prevalent misunderstanding. Either that, or I have been...
Hi, I have a project I have been working on, that has me out of my depth with regard to my knowledge, as I am a very basic electronic hobbies...
