SuperlecDirect - ElectriciansForums.net Electrical Suppliers
Discuss what is the MOST likely cause of high resistance when testing continuity of cpc in the Electrical Forum area at ElectriciansForums.net
hi guys,
what is the MOST likely cause of high resistance when testing continuity of cpc?
I know likely reasons could be loose terminations, bad terminations (e.g not all wiring strands in connection), dirty connectings, ect
But what would you say is the MOST likely reason for the high resistance reading fault?
thanks magpie
Aico Carbon Monoxide Detectors
Deleted member 26818
Depends how you are conducting the test.
If using a 3 pin plug lead, then corrosion in socket.
Otherwise, as you say a high resistance joint.
Silly Sausage
hi guys,
what is the MOST likely cause of a high resistance MEASUREMENT when testing continuity of cpc?
Also, a bad contact with your probes for the above.
Have a good scratch with your probe tips or crocs to make sure you get a good contact.
K
Knobhead
Tell us what you think could cause the problem. We'll help then, this isn't a homework site.
Richard Burns
Mentor
Most likely would be an insecure termination.
Corrosion, wrong size cables, poor continuity of conduit used as cpc, would all be longer term problems but the loose connection is more prevalent I would say, but Archy's one is good.
  • #7
thanks guys,
yeah archy made a good point about the probe tips, but i think its looking more at faults on the installation.
thanks again guys
sparks1973
always grab both crocs around conductors...hold em firm when in DC low ohms.....best way that...
low batterys in MFTs/seperates will give stupid values sometimes.....as mentioned above high resistance joints...spurs of course and dirt/filth in shutters so wipe the plugtop in and out a bit till it clears and oxidisation/scale on bare CPCs (especially older cable).....
Reply to what is the MOST likely cause of high resistance when testing continuity of cpc in the Electrical Forum area at ElectriciansForums.net
uHeat Banner - Forum Discount Available
Select the ways in which you gain online business
  • MyBuilder.com
  • Federation of Master Builders
  • CheckaTrade.com
  • RatedPeople.com
  • TrustaTrader.com
  • Which? (TrustedTraders.Which.co.uk)
  • MyJobQuote.co.uk
  • Yell.com
  • Google Paid Advertising
  • Own Website with Natural Ranking (SEO'd website)
  • Social Media (Facebook Twitter Instagram etc)
  • Word of Mouth Only for me
Results are only viewable after voting.
Bulk Workwear - Clothing Suppliers for the Whole Forum Network
Top Bottom
