Discuss What is the standard spec for A/C Rotart Isolators in the UK market, mainly Air Con in the UK Electrical Forum area at ElectriciansForums.net
skysparks
I am electrical cable distributer so getting a little lost with the component side.
Looking to purchase some Rotary Isolators direct from a manufacturer and getting a little confused with the specs and certifications used in UK so wondered if anyone can help.
So far I know the following.
25 Amp 4Pole
32 Amp 4 Pole
They are the standard Grey with yellow and Red rotary switch.
They meet with IEC60947 .
Volage always for 415V
The above should be usable for single phase or 3 phase correct?
CB and SEMKO certification.
Can anyone tell me if this spec looks ok and also what's the difference between surface installation and Din Rail installation?
Any help would be greatly appreciated.
Re: What is the standard spec for A/C Rotart Isolators in the UK market, mainly Air C
Hi Sky The CB and SEMKO certification are "International" However the IEC 60947 is European. That is as far as I understand the rather strange and over complicated system. The best way for you is to Google the various standards and see if they are the same or at least comparable. Personally I would suspect that they are in all respects the same but who knows ther may be something spookily different. I started to read an explanation but lost the will to live so had to stop.
As for your question...if cost and space is not an issue then you can use 4 pole switch on single phase. Be aware that the neutral is for the neutral as it may break last.
SEMKO Article
Regards Philpot
Reply to What is the standard spec for A/C Rotart Isolators in the UK market, mainly Air Con in the UK Electrical Forum area at ElectriciansForums.net
Hello everyone, I really hope this isn't an idiot question but boy, I'm out of my depth! I've spent about 3 weeks (not solid mind) trying to work...
C
Will these be any issues running a Chinese 3 phase motor, 380v 50z motor on standard UK 3 phase mains? Will be used for a few hours max each day...
9K
Hey peeps! First of all hoping you all had a sound bank holiday weekend (mine was obviously working and earning the pennies but hey ho)...
4K
