Discuss What is this gland for? in the UK Electrical Forum area at ElectriciansForums.net
unusual to see the knurled taper when there's a tapered collar. is it a case of "get a grip , man?"
Nope
See loads and loads of swa 'terminated' into black plastic stuffing glands on new builds etc
especially on outdoor lights etc
Problem is this still requires some level of skill to termination properly...
The way i keep seeing Swa installed recently is they cut off all the armouring and just take the inner cores through the stuffing gland.
i'll never master a computer while i have a hole in my arse. spawn of the devil. never do what you want them to do, and then they mix it all up. still what do we expect from something that can only count to 2.
Reply to What is this gland for? in the UK Electrical Forum area at ElectriciansForums.net
Hi all, our summer house had a FuseBox consumer unit fitted last year and the guy who did the work has retired. nothing wrong with the install...
Hi All, Just started upgrading all my out building for power and data and i was wondering rather than cutting off the ducting at floor level, do...
On a domestic Cu 60 amp would live and nuetral tails cause eddi currents of any significants if the tails were run in sperate metal conduit but...
As the title says, I am looking for a recommendation for an enclosure and gland arrangement to electrically isolate or divorce the earth/armouring...
4K
I'm working on a system that has been installed incorrectly. It's a 3ph Hager board with 8 swa cables glanded into the bottom entry panel. The...
