Discuss What is this?! in the UK Electrical Forum area at ElectriciansForums.net
Some sort of LED lamp. Could you post clearer pictures of each end.
looks similar to the tail light bulbs on my van. chinese imports. lasted 6 months.
Its hanging above a counter top in a pendant style light fixture. its gone out and I cant seem to find a replacement anywhere. I feel as though there should be something out there without having to replace the entire fixture, but i could be wrong. There does not appear to be a connection to just the bulb. Its wired right in.
Go 1000 bulbs just google it these people are quick to respond and can probably help you more than we can
Reply to What is this?! in the UK Electrical Forum area at ElectriciansForums.net
I have a street light circuit on land I rent out. I need to replace 2 of the bulbs. 1 of them is an old Philips 55W SOX Plus, the other is a...
Hi we are replacing light fittings in our home. Im confident with the fitting aspect, but have run into doubt in making the right choice of...
I have 3 pendant light fixtures with a total of 540 watts of incandescent bulbs connected to a GE electronic dimmer. The bulbs flutter from bright...
We bought a house with an array of broken (some cosmetic issues, some functional) downlights under cupboards in our kitchen. The bulb seem to be...
This is the second set which won't work to replace the current spots here in my kitchen. All they do is flash once quickly. I'm replacing...
