Discuss What is "unwanted tripping"? in the UK Electrical Forum area at ElectriciansForums.net
So why wouldn't a 13amp fuse blow before a 32amp circuit breaker?
Just look at the current/time plots for them.
Typically with a fuse and larger MCB you will find generally:
  1. The fuse blows first (up for PFC up to the MCB magnetic trip point)
  2. Then you find the MCB trips first, and the fuse survives (if MCB I2t let-through is below the per-arcing I2t of the fuse)
  3. At very high PFC you find the MCB trips but the fuse has also blown (as the blows in under the time for the MCB to operate, typically 5-10ms).
Rational Argument:
Domestic general purpose socket outlet circuits;
2.5mm ring final circuit, protected by 25amp BS EN 60898 mcb, supplying BS 1363 plastic socket outlets.
Light industrial general purpose socket outlet circuit;
4.0mm ring final circuit, protected by 32amp BS EN 60898 mcb, supplying BS 1363 'metalclad' socket outlets.
History:
2.5mm ring main, protected by 30amp fuse carrier with 20amp fuse wire/cartridge, plastic socket outlets.
Light industrial general purpose socket outlet circuits;
4.0mm ring main, protected by 30amp fuse carrier with 30amp fuse wire/cartridge, 'metalclad' socket outlets.
Rational Argument:
The argument being?
The important working parts of a metalclad socket-outlet (near the points at which heat is generated) are usually made of the same plastics as an all-plastic one, although an enclosure with more of its surface made of metal might provide better containment of burning material from within. Within a BS1363 plug and socket-outlet pair, heat is generated mainly at points of high current density, such as (in approximately decreasing order of significance)
  • Fuse element
  • Fuse clips
  • Socket contacts
  • Switch
  • Plug terminals
  • Socket terminals
Thus two of the principal sources of resistive heating are outside the containment offered by a metal socket faceplate anyway. The quality of manufacture, installation and any deterioration of the contact surfaces are key factors in the resistance at various points and the heat generated. So too is the effect of heat on the long-term stability of resistance, which is markedly poor in low-quality accessories.
Or have I missed the point? This whole thread seems to be an exercise in trolling by someone with knowledge of electrical principles, or an attempt to cheese everyone off by someone without, by repeatedly making false statements. I can't tell.
If you look on the home page the envelope in the top right corner should indicate a message. Reply to this message.
Don't think the OP will be back if you catch my drift :)
Thanks everyone for resisting the urge to say what you really felt.
It's a strange carry on. I dare say he'll be back with some more bizarre postings in a few months.
Reply to What is "unwanted tripping"? in the UK Electrical Forum area at ElectriciansForums.net
Wallbox Fuse Box Lite Single Phase has anyone used one of these? I've installed one feeding a Pulsar Max, the Pulsar Max is set to 32Amp max. The...
I have just checked a double outlet and it trips at 18ma. It was supposed to be faulty. Washing machine had a bad heater which got replaced but...
This for an apprentice 32 amp mcb /63amp RCD 1) no power to the sockets 2) installation resistance all good. 3) contunuty good. 4) no loses...
What should you do if a client has a CU that is a split board protected by 2 * 63Amp 30mA double pole RCCDs, you took Zs and tested both RCCDs by...
