- Reaction score
- 5,578
Being a domestic installer I can safely say I don't even know which part of the photo we are looking at. Interesting reading all the responses though .
Discuss What kind of motor is this? in the Electrical Forum area at ElectriciansForums.net
LN is a master at framing his image. Why for example:
1. Is there a box with vents? (Which looks newer vintage to the motor.)
2. are there 3 lengths of vertical conduit?
3. are there 2 lengths of flexi conduit going under the box with vents?
4. do the connections to the motor (middle conduit) not directly connect to the vented box?
5. Where do the 3 vertical conduits end up?
6. Is the bottle a clue?
I think our posts crossed! If you know organ blowers, there are indeed lots of clues.
1. Transformer-rectifier for the 18V DC electric action. Yes it's newer.
2. To keep it off the floor, it's run across the ceiling.
3. No specific reason.
4. No, quite separate.
5. Motor supply from DOL starter, rectifier supply from contactor, rectifier output to DC busbars
6. Incidental. There are often old bottles of oil in organ blower rooms.
Organ clues include the Watkins & Watson shaft coupling, tantalising glimpse of flexible coupling top right, a similar hint of wind trunking, ancient masonry and age of plant. Organ blowers have a very high moment of inertia and have to start against heavier load that is usual for a fan or pump (because they are rated to work against backpressure and can overload the motor when filling the reservoirs). Hence the preference for an RSIR where there is no 3-phase supply.
Well Marconi is close enough that I have to give it to him. Yes, made by BTH, yes brushes are shorted together and run on a comm to create rotor repulsion, yes power is applied to stator only. However, repulsion is only used for starting - it's a Repulsion-Start, Induction-Run (RSIR or R/I) machine.
There are two ways to do this. Century and others in the USA, used a centrifugal mechanism like the starting switch of a split-phase induction, but instead of operating a switch, as the motor approaches full speed it does two things. It triggers a spring-loaded actuator that lifts the brushes off the comm (to save wear) and puts a shorting ring around all the commutator segments to convert the armature into the equivalent of a squirrel cage.
This BT-H (then part of AEI) avoids the centrifugal mechanism by having two windings on the rotor. The repulsion winding brought out to the commutator, and a separate squirrel cage. At a standstill, the high slip frequency puts the cage current out of phase due to its inductance (which is why inductions typically have poor starting torque.) But the repulsion winding takes over and accelerates the motor, at a speed and direction controlled as Marconi mentions, by the setting of the brush rocker. As the speed increases and the slip frequency reduces, the cage torque dominates and the relative placing of the windings in the slots causes the magnetic flux to bypass the repulsion winding, so the motor runs as an induction. Unlike the Century there is still brush wear, but it is low because the brushes are passing minimal current.
Why go to all this complication to start an induction motor? Simply because repulsion motors have excellent starting characteristics. Smooth and torquey, without the excessive line current required by other starting methods, despite being single-phase (which were always inferior to 3-phase at starting). RSIRs handle high inertia loads and starting against full torque, but once running they are not as efficient as inductions and lack the near-constant speed. Hence, to deal with difficult loads with only single-phase power available, start as induction for best torque and lowest overcurrent, then run as induction for best efficiency and stability.
I've no idea why Tel sees it heading to the skip. It's worked fine for 80 years and will probably be good for another 80. I'm sure skips will have been banned by then.
The round thing bottom centre
I did not remove the CU containing the 45A mem fuse holder
some cast iron control gear for vetilation equipment recently,
My late father used to tell a tale about a call to a factory where there was a long bench with lots of sewing machines driven off a line shaft - and with a motor at the end to drive it. He opened the lid of the enclosure expecting to find it solid with lint - but instead found it spotlessly clean.That motor is repulsive.
Needs a make over.
Reply to What kind of motor is this? in the Electrical Forum area at ElectriciansForums.net
