Discuss What MCB fits in Lewden CU in the UK Electrical Forum area at ElectriciansForums.net
robo83
Hey guys,
Just had this pop up on me tonight.
I need to install an MCB into a lewden CU tomorrow morning and I don't have a local wholesalers that sells them.
Does anyone know what MCB fits into this board please (other than lewden)
Anything other than Lewden compromises the principle of maintaining a type tested coordinated assembly, and may come back to bite you if something goes wrong in the future, related or otherwise.
Thanks for the replies.
This is to test a temporary supply to a pump that will be run for a short period of around 15minutes, the board is a temporary setup
I was hoping there would be another option than change the board but doesn't seem that way..
my post above explains why.
This just landed on me tonight, I was going to pop to the site in the morning as the existing MCB is overrated and needs reducing.
It's only a temp setup to commison a pump and I would be in attendance at the board the entire time..
I will see what options I have in the morning at the wholesalers and if they don't have one I'll swap the board.
Hang on.....did I read this right??? You're gonna change the board which is temporary anyway for another board which I assume will also be temporary so you can test a pump for 15 mins which you will be monitoring the whole time!!! Lol
Why not stare at your clamp meter for 15 minutes with your overrated MCB still fitted instead haha :)
The company commissioning the system will only sign off the system if it comply with their spec (this is what I just got in message). Tick sheet stuff probably.
Ill get a new board and see how it goes in the morning once I meet the enginner.
Reply to What MCB fits in Lewden CU in the UK Electrical Forum area at ElectriciansForums.net
I'm obviously still new and learning about what I can and cannot do, but essentially I want to install an EVSE at my own house for an electric...
This from a while ago but reading about everyone elses problems tonight made me remember this one. The original job was the lights in a recent...
We are looking for a distribution board to provide 3 * 160A three-phase feeds, but they are basically redundant supply path options so max total...
Hi fellow sparks, I've just started out on my own so I'm spending a lot of my time trying to find out the correct way of doing things of...
