Discuss What PIR do you give appliances with no Isolation switches in the UK Electrical Forum area at ElectriciansForums.net
Hi guys,
Just curious to see what P.I.R code other people would give kitchen appliances with inaccessible plugs that have no means of isolation.
I came across a cooker, dishwasher, washing machine and bathroom extractor fan yesterday and C2'd it.
I notice on the electrical safety first website that they say 'fixed equipment' should have a means of switching.
the plug and socket are a means of isolation. poor accessibility would warrant a C3 at worst.
If it's got a plug on it but is firmly screwed into 1 position would they be classed as fixed? I understand it can be unplugged but it can't be moved without unscrewing it out of position? Just a thought
but who wants to screw a dishwasher?
Depends how nicely she asks........
If it's got a plug on it, then it isn't fixed equipment - it's portable.
I think you would identify it as stationery equipment :), as for coding in the ops case I would go for a code 3 and identify in the limitations that you could not inspect this part of the installation.
C3 even if plug tops are not accessible without pulling out the washing machine?
What about no fan isolator switch? C3 also you reckon?
Ok, to play devils advocate - let's say there's an outlet on a wall behind a wall mounted TV. The mounting bracket is mounted in such a way that it's impossible to isolate without first removing the TV, and this particular bracket requires a tool (no, I'm not the tool!) to remove the TV. Would you mark that as a C3 for poor isolation too?
You should be supporting your observations with reference to specific regulations that are being breached, and your codes should reflect the clearly defined meaning of those codes.
I suppose that the question is "How does this feature reduce the SAFETY of the installation?".
Ultimately, if things are going seriously wrong with the appliance, you can switch off at the board providing that it's not in a locked cupboard.
When I phoned Elecsa technical a while back. He said you can do away with fused Spurs if the appliance socket is accessible (i.e in a local cupboard next to it)
But maybe this is more advised in a new installation?
I think I'm right in the word I used - if you google "define portable appliance" most definitions come back something along the lines of "an appliance that is plugged in that CAN be moved". I've yet to find anything that says it is limited to things that can only be moved easily.
careful. you'll be getting as pedantic as pete next. :tt1:
Reply to What PIR do you give appliances with no Isolation switches in the UK Electrical Forum area at ElectriciansForums.net
  • Locked
5K
I have been asked by Trading Standards to carry out a report on some electrical work installed by another company (5 years ago). The 'new' wet...
Hi, First post so go easy on me. Looking for some advice on kitchen appliances (washing machine, dishwasher and fridge/freezer) because I have...
Hi guys. Electrician will soon rewire my kitchen and some questions arises about sockets and isolator switches. I think they look ugly and don't...
18K
HI I'd originally planned to have an mk grid switch located just above the worktop with four modules and each module a DP switch to isolate...
6K
