Discuss what size conduit for 6mm t&e? in the Australia area at ElectriciansForums.net
Cheers guys, my thoughts were 32mm would be fine - surely 20mm would be a bit of a push,
cheers durham got 6mm single but using T&E due to the route the cable is taking (under floorboards) from cu before it goes in the conduit for the final part.
If the 6 mil ft+e is the only cable then I would say a 25mm conduit. A 32mm conduit is sensible if you want to leave an option for another cable in future. 38mm is a big chase if it's going in a wall. If it's a single skin wall you might have structural considerations at this size.
Reply to what size conduit for 6mm t&e? in the Australia area at ElectriciansForums.net
Client currently has a DB in his outhouse. It feeds a pool pump and an air source heat pump. It is currently being supplied using a 4mm T&E cable...
I have had my kitchen rewired and plastered. I have had a 6mm t+e on a dedicated 32a circuit for a 60cm electric cooker. In hindsight, had i known...
I'm obviously still new and learning about what I can and cannot do, but essentially I want to install an EVSE at my own house for an electric...
Hello all, I wonder if I can get some opinion on my deliberations on an old TPN installation with numerous 1P sub-boards wired up with 16mm T&E...
Hi, My first post so hopefully I am correct in posting it here. My question is, I am thinking of an IP rated outdoor socket for the back garden...
