Discuss What size Fuses do I require? in the UK Electrical Forum area at ElectriciansForums.net
Hi,
I have a three phase switch fuse supplying a 16A socket. In the specification provided it states the following:
Design Current - 16A
Main Protective Device 20A
The circuit is fed from a C20 MCCB at the distribution board.
What size of fuses should I be putting in the switch fuse?
16A or 20A?
Thank you.
Hi,
16A or 20A?
Thank you.
Don't mean to be funny, are you an Electrician? do you have any electrical experience? sorry for the questioning but your profile reveals nothing.
I am a trainee electrician and it is a question asked today at college to which the discussion never revealed a correct answer, we thought that it would be 16A fuses due to it being a 16A socket.
I can't answer your question but I believe there is a trainee section that will be able to help with these types of question and many more that you may have without the snide comments ;o))))))
Good luck in your training, I'd just use Wriggleys chewing gum wrapping to be honest but then you won't pass any exams ;o))))))
and of course, you leave the partly chewed gum in there as a flash guard, even though it's more hazardous than asbestos. i can honestly say, i've never got my shoe stuck in discarded asbestos.
Not being funny either Pete999, but your profile doesn’t show your qualifications either, even outdated ones.....
Yeah we are getting a fair few reports about the constant questioning of quals and empty profiles, maybe we could just start answering the questions with a relevant answer.
Cheers
GMES
Thanks Gavin, it makes it easier to answer that's the reason for asking
Thats because I fell in line, and deleted them I will put them back on tomorrow even the outdated ones if you wish me to.
Pm sent Gavin
Cheers
GMES
Perhaps some discussions among staff members would be a good idea, all on the same page so to speak.
To the OP I believe if you look in GN1 it gives a suggested maximum overcurrent protective device of 20A. I believe this is due to the fact a radial of more than one 16A socket can be employed, after this 32A, 63A etc... are suggested to be single point radials with a protective device used to match their rating. If however the circuit supplies one 16A socket I see no reason to use anything above a 16A protective device.
this question is problematic.one would assume that the 16A circuit would be protected with a OCPD suitable for the cable and load. so 16A or 20A would be appropriate.however,you'd not achieve discrimination with the 20A MCCB. catch 22 here.
great thoughts pete,but please translate them from latin for the younger members. :D:D:D.
Staff do discuss things and I know exactly what you're referring to, which proves we do.
My only point is that we are getting reports by members that it is becoming almost a stock question.
As for incomplete profiles even if was compulsory it would not guarantee that new members would fill them in truthfully.
All we're asking is for you and others to evaluate the question from any given op and answer that question, it can almost put the op or thread on the back foot before it's begun.
That's all we are asking , nothing more nothing less.
Cheers
GMES
Not sure I agree with that.
New members do not open up their profiles so we are all guessing ................
This is not a DIY superstore site...........
Reply to What size Fuses do I require? in the UK Electrical Forum area at ElectriciansForums.net
Hi all, Been browsing these forums for a while, always great to learn a new way to skin the same cat. Anyway, cut a long story short, was an...
Hi guys. I was wondering what size cable and braker I'd need for an electric shower. Just out of intrest am I close in guessing as follows: The...
I live in Thailand and my home has 240v, 3 phase power supply. I want to add an electric car charger but first want to determine what the outlet...
Hello all, I wonder if I can get some opinion on my deliberations on an old TPN installation with numerous 1P sub-boards wired up with 16mm T&E...
