Discuss what size grips for 240 swa singles? in the Industrial Electricians' Talk area at ElectriciansForums.net
J
jibspark
Hi all,
ive got a job comming up where i will be glanding alot of large swa's, most about 240 singles i think.
what size grips do you think i will need? all ive got at the mo is bog standard 10" ones.
ive always used grips, i agree that spanners would be alot kinder to the gland but i would end up spending a fortune on different sizes.
Where necessary, on large glands, I hold the tightened base of the gland with a spanner and use stilsons to tighten the "armour lock". Have found in the past that stilsons tend to be too thick to hold the gland base without getting in the way when tightening the "armour lock".
"2 pairs of 36 inch stillsons " and why would they slip ,ive never had a pair slip yet and never marked a gland bad enough to worry about it ,
good luck
hang on 240mm singles are we talking transformer/switchgear if so the armour will be ally so will glands, probably 32/40 gland so not very large,also non ferous gland plates
yourse benji
460 channel lock from rs about £20 each
benji
thats a good point! i think they are 40's.
theres me thinking about a 4 core or something but actually they are gonna be pretty small. sweet!
yourse benji
benji
Well spotted benj ,i was thinking about 4 core armoureds ,ive never had anything to do with singles or ally glands ,but ive done quite a few big armoureds ,but i missread the origional question ;)
once did some 630mm 3 per phase used erma thick wall lugs when you crimp with hyd. crimper hex dies you had to allow for lug increasing in length (cocked up first one )always lug them about 4mm short now
yours benji
yours benji
Yep, done some 630 singles for Water Board. Enjoy big stuff better !
Reply to what size grips for 240 swa singles? in the Industrial Electricians' Talk area at ElectriciansForums.net
Hi, thanks for reading this. Ive been asked to look at a job where the DNO connection (single phase 80A TT) is a long run to the final circuits...
Hello Everyone -- So, I am looking to buy a used 5HP 3PH 208 V 10 inch Table saw --- (Motor Plate Data in Image) I am a DIY'er and in...
Hi I've inherited a very tight space, a KMF switch and some split-con for a sub-main to try and tidy up. It's a joyous non-restrained single...
Hello all, I signed up here for a little help. I bought a 3 phase bandsaw and went down the rabbit hole of VFD’s etc. ‘The motor is 3 phase 400v...
