Discuss What size wire should I use? in the UK Electrical Forum area at ElectriciansForums.net
Ryan0601
I am putting in an above ground pool about 350 feet from my electrical box. I would like 30 amps out there. I will add some lights and a fan. Normally I would do 20 amps, but if I ever want to use a pool heater, I will need 30 amps. I already have conduit buried.
I have used multiple online calculators and received multiple answers. What size wire should I run for 20 amps? What size wire should I run for 30 amps?
240V or 120V???
@240V i would think awg 6 or awg 4 (copper) to have acceptable volt drop, however, your regs. are different to ours, so maybe a US member can help better.
Tennessee? is this for a moonshine still?
Ryan first off do you have a panel at or near your pool so you can distribute your power. As @telectrix said are you talking about 240vac or 120vac, 350 feet is a long way from your house, but at 20 amps you would need at a minimum of # 6 and for 30 amps you would need # 4 to avoid voltage drop. You said that you already have a conduit already ran out to your pool so if you are going to pull single wires the pipe would need to be 11/2 pipe. If you are going to pull cable instead of singles it would need to be 2 inch. Regardless I hope you have help because that’s going to be a hard pull. Good luck
Thanks. I can put in a sub panel to distribute it. It is 120. I will definitely have some help. Thanks again.
Reply to What size wire should I use? in the UK Electrical Forum area at ElectriciansForums.net
Mobile home outdoor power supply is a pedestal that power to the mobile home plugs in much like an RV. The main power supply into the mobile home...
Hi all. We have a 120v 20 amp circuit to an accessory dwelling with a run of about 75' of direct bury #12. The breaker keeps tripping even when...
At long last my wife is getting her new kitchen and the contractor will be running 10 or so new circuits from a new sub panel. The sub panel...
I’m running wires to the basement for future basement finishing. I’d like to add two circuits of outlets (one on the finished side and one on the...
