Discuss What they trying to achieve here then? in the UK Electrical Forum area at ElectriciansForums.net
Our gas supplier wasn't happy that our meter was on a meter shelf and not a meter bracket. I'm not sure what he thought was going to happen, the meter was up out the way and plumbed in copper pipe... He made it safe by removing the shelf, fitting a bracket and fixing it to the wall with one screw. :)
Our gas supplier wasn't happy that out meter was on a meter shelf and not a meter bracket. I'm not sure what he thought was going to happen, the meter was up out the way and plumbed in copper pipe... He made it safe by removing the shelf, fitting a bracket and fixing it to the wall with one screw. :)
That figures jobsworth types peev me orf
You can remove the meter and turn it around or bypass it if it is on a shelf. The brackets should have shear bolts which prevent the meter being removed without making it obvious that it has been tampered with.
[automerge]1578073075[/automerge]
Why it's safe on the floor, isn't it???????
It's safe but far too easy to steal gas, the bracket prevents this.
This was a 3 circuit eicr for a couple that are buying the house, deceased estate I believe, which means some scumbag has had an elderly person over with that instal.....they haven’t even bothered with any gas or water bonds!
Look guys I simply ran out of bonding clamps...
So just grabbed some all-round wrap banding to attach the main earth
I thought it was a pukka job
Reply to What they trying to achieve here then? in the UK Electrical Forum area at ElectriciansForums.net
Hi as per title I'm building a sublimation heat press. i have a 1000mm x 250mm x 8mm sheet of cast aluminium. i will be using a thermostatically...
I’m probably going to look stupid here, but it will be worth it if I get the answer 😆, as I can’t fathom it out. I’ve never really thought of it...
As per title. Does anyone know what this symbol means? It’s on a IP rated outdoor light and there’s nothing in the instructions to say what it...
hello , Just a note to see if anyone been in the same sort of journey as me? I wanted to retrain as an electrician at 40 and on bad advice did a...
I have a small Consumer Unit fed from a 6 amp type B mcb to a 6 amp type B,it only feeds 1 light in a bin store . clearly we have no selectivity...
