Discuss What this? in the The Welcome Forum area at ElectriciansForums.net
telectrix
Mentor
looks like a link with a bit broken off, maybe out of something like a din rail terminal block.
snowhead
Mentor
Similar to Phone IDC connections, push the cable in from the top, or as in picture from the left.?
Was it in the motor?
It's unlikely it was used in the motor, apart from maybe the Thermistor, more likely fallen it from elsewhere.
static zap
Advent Win
As @ snow head mentions ,looks very IDC
(insulation Displacement connector).
Is it mildly magnetic ,possibly attracted to motor ?
  • #6
Hi everyone, maybe somebody knows how exactly you call this terminal plate? I took from water pump motor connector Thank you
telectrix
Mentor
that looks suspiciously like the bit in the OP came out of there.
Top left on your first pic you can see where it belongs, the winding wire is no longer connected. The part clearly comes from there.
static zap
Advent Win
Sadly a lesser wanted continuation of the phrase
" You've pulled " ... too hard and are holding a wire with
a terminal attached .... and a thin brown wire dangles somewhere ... snapped off .. near invisible !
  • #11
[QUOTE = "sniego galva, pranešimas: 1547917, narys: 50587"]
Panašiai kaip ir telefono IDC jungtys, stumkite kabelį iš viršaus arba kaip kairėje.
Ar tai buvo varikliu?
Mažai tikėtina, kad jis buvo naudojamas variklyje, išskyrus galbūt termistorių, labiau tikėtina, kad jis nukrito iš kitų vietų.
[/ QUOTE]
how you call this connector plate? I need replace
CK Tools :) The professionals choice when it comes to Electrical Tools
Reply to What this? in the The Welcome Forum area at ElectriciansForums.net
Aico 3000 Range
Top Bottom
