- Reaction score
- 2
Hi guys,
I would be hugely appreciative for any input on this.
Basically my electrician did a full rewire and didnt use any capping or conduit, which as I understand is OK within the regs (as long as RCA protected which they are), but considered a bit unprofessional in the trade depending on who you talk to.
The electrician 'made Good 'in the chases for an extra 100 quid. I said about the wires poking out and he said it doesn't matter as the plasterer would be going over them. I think the plaster is usable, as such I dont need to have the walls replastered. So now I need to know what to do with these chases sonI can get the wires under the surface if the wall.
My instinct on the last 2 (dining room) is that I can chip away the existing plaster that he has used and push the wires back and go over it with a filler so that they sit properly in the chase. I'm a bit afraid of doing it though as I'm scared I may damage the wires. Also it looks like the wires have crossed over each other in the chase..is that supposed to happen/ok?
My biggest concern is the picture below where the wire is dropping from the ceiling (breakfast room) in the chases. No amount of plaster would set that right..it just looks like he hasn't used enough wire.
I am really at a loss as to what I can do. As far as I am aware as there are no regs broken I dont have the right to demand he comes back and fix it. But I dont know what I can and can't do.
If you guys could let me know how you would deal with this I would be hugely grateful. Any input at all...its honestly cooking my brain!!
Cheers!!
Cheers!!
