Discuss What to fix a garden socket to. in the Australia area at ElectriciansForums.net
I
ihugs
I have to install a socket in a garden but do not have a permanent structure to fix it to can anyone give me any ideas, thanks.
What about using the special locn regs that cover posts in caravan parks ...eg the use of poycarbonate posts etc ..
perhaps a wee bit of overkill for a gardens socket But you will be super duper Ok. :)
72-van
nothing wrong with a wooden stake. good dollop of creosote. whack it in with a sledge. job's a good'un. ( useful for burning the local witch as well )
Reply to What to fix a garden socket to. in the Australia area at ElectriciansForums.net
Evening everyone . Currently looking at pricing a job up . It’s a hot tub supply . Outside socket with a few spare ways in an outdoor cu . 10mm...
Hi, I have recently moved in to a house where there is a switch outside the bathroom that controls the power to the shaver socket. Never seen...
We have an outdoor socket that is hard wired into the ground floor power circuit and protected with an rcd in the consumer unit. I now plan to add...
Currently I have a Henley block which has 2 consumer units. 1 of these CU feeds a garden supply and garage. Out in the garden which is fed by a...
Hi guys, Can I ask you a DIY question? I'm refurbing a detached garage and adding a garden building. Garage currently has a submain supplied by...
