Discuss What type of bulb is this? in the Lighting Forum area at ElectriciansForums.net
I have this bulb that needs replacing. Markings on it are: 2817, 240V 150W, C2b8, Germany. What type is this please? Also, can I replace it with 150W LED equivalent?
Looks like a standard edison screw.
Direct replacement with LED however they are far more energy efficient than fillament type lamps. So 5 - 7 watt would be a good replacement.
I originally thought that but the shape of it is getting me thinking maybe it’s a metal haylide or similar.
I at first thought that, however I'm finding it difficult to judge the size of it. Going off the wood grain and the fact there are is no symbol for internal or external igniter on it swayed me to thinking standard Ellison.
C2b8 is the lamp shape designation, but google isn't throwing up any results.
Just looks too small for an ignition type lamp, need something else as a size reference.
Ok, I have exactly that lamp, except the markings are:
2817
240V 150W
C168 this is the only difference and it may be that the OPs lamp is actually this one but the markings are not clear.
Overall length about 11.5cm, max diameter about 4.5cm, if that helps.
I have this in my Ikea uplighter, which is no longer available, nor is the glass shade which the removers broke, nor is the bulb/lamp.
It is a standard ES fitting, so any equivalent will be fine.
2817
240V 150W
It is C2b8 marking. You are right - got it on an uplighter from Ikea. Strange but my glass sed on it broke and I have a replacement shed different to before.
What confuses me is the 150W mark. Surely this cannot be Incandescent 150W in an uplighter? Hence the question on LED of 150W
2817
240V 150W
So what type of lamp is it? discharge, LED, halogen?
If it's an Ikea fitting and it 150 watts then it will almost certainly be incandescant or at least some type of filament like halogen.
In the interests of reducing the number of dead dolphins and assuming it's not running on a dimmer, replace it with a 15 watt LED lamp (bulb) that is a recognised make has a standard ES base and looks like it will generally fit.
I believe it is an incandescent lamp. It's the top, uplighter part, of a dual=purpose lamp, with a swivel, lower level reading lamp which is a 40W screw -in reflector. Yes, the top lamp is on a sliding dimmer.
Times change, eh?
If it's got a dimmer then you just need to find a 15w dimmable LED as a replacement. There is however a possibility that the dimmer may be unstable with the smaller load.... it will be trial and error.
Yes Marvo...but of course the dimmer was built long ago, so for a dimmable LED trial and error will be the way...
or, contrary to current thinking, a simple incandescent or halogen will be fine. The world will not end...
Can you still get incandescants? Not a problem in my neck of the woods but I thought they'd been phased out already where you are.
(taps nose with forefinger...)
yes, of course you can get incandescents...
I have 100 standard 60W ones in my garage.
I also have 40 GU10 halogens, 35/50W, free to a good home.
Sorry...I have about 35 of them, cos i supply all the old dears in my block with the odd one when they have a failure...
Seems fair, to use up the stock, no?
I thought you lived on a pirate ship you are deluding the image.
Reply to What type of bulb is this? in the Lighting Forum area at ElectriciansForums.net
Hi all. Slightly out of the ordinary, but I'm looking to replacing between 60 to 100 standard size E27 bulbs with LED equivalent. The catch is...
Hi I currently have 4 led bulbs in the bathroom and 3 of them arent working. The bulbs that are currently in are LOMAS LED GU10 220-240V 6000k 6w...
This is the second set which won't work to replace the current spots here in my kitchen. All they do is flash once quickly. I'm replacing...
Hi all, Great forum with lots of advice read and greatly received over the years! I have a question here that I am hopeful somebody here can...
Can I use multiple GU10 led lamps with their own PIR sensors in the same room? I have a row of existing lamps 600mm apart in a straight line & I...
