Discuss What type of consumer box in the UK Electrical Forum area at ElectriciansForums.net
Hi, I am sure it has its own 32amp circuit connected to the garage cu..why it has a fused spur before going outside ??All seems a bit of a strange design, he'd have been better running the SWA back to the Garage Consumer unit and putting the bar on it's own circuit. An MCB in an Rcd protected consumer unit isn't ideal for a distrubition circuit either. If the sockets in the garage are a ring then the fused spur would need to stay, it wouldn't matter if you used 25mm cable, the entire bar area would still be a spur off the ring and the limit for that is just 1 single or double socket.
Your photo shows a fused spur labelled "Pauls Bar" with the SWA cable heading out of it?Hi, I am sure it has its own 32amp circuit connected to the garage cu..why it has a fused spur before going outside ??
After all these comments its bugging me now.. I will isolate leccy 2moz and have a look around the fused outletYour photo shows a fused spur labelled "Pauls Bar" with the SWA cable heading out of it?
Not sure why it has an IP rated enclosure either given it's right beside a socket that doesn't. Strange setup.
It says Electric Cable BS 5467 ce 600/1000 vsome armoured cable has its size embossed on the outside, every meter. will be something like BASEC CABLE BS123455* 3 X 4SQ MM
have a good look, it might give you a clue as to what cable it is.
Reply to What type of consumer box in the UK Electrical Forum area at ElectriciansForums.net
