Discuss What type of fuse is this? in the Australia area at ElectriciansForums.net
Stever_777
Hi guys, can anyone tell me what type of fuse this is and the current rating?
The only thing written on the fuse is BICC and Made In England
Seal was already cut....HONESTLY.......have pulled the fuse and found no more info on back guys.
Would the supplier tell me the rating?
Personally I wouldn't touch it. The supply side is massively dangerous as it'll be fused at 100s of amps back at the sub-station so a short circuit could cause an arc blast that'll take your face off and set fire to your house. The DNO sparkies tend to wear some serious PPE when pulling these fuses.
With a modern unit like that the chances are very remote if it’s done with no load. With old porcelain carriers then I’d agree with you.
IF YOU DONT KNOW HOW TO DEAL WITH OR HAVE BEEN TRAINED ( you obviously havent been traind nor are you IMO Competant to "PULL" a DNO fuse as you dont know enough about it not even that it requires opening to locate the fuse i realy WORRY ABOUT PEOPLE SOMETIMES ffs
Reply to What type of fuse is this? in the Australia area at ElectriciansForums.net
Hi all Please can anyone tell me the type and breaking capacity of a 60amp bs5419 isolator fuse like you'd find in a sub main for a flat. thank...
I have a question which is confusing me and I cannot find a definitive answer and I hope someone can help. So I have a PC and Monitor and I have...
Bit of a long shot on here but does anyone have a circuit diagram for a Chavin Arnoux CA 6545 5kV tester? I've copied my post on EEVBLOG forum...
Hi all, Been browsing these forums for a while, always great to learn a new way to skin the same cat. Anyway, cut a long story short, was an...
Evening all, I'm relatively new to the trade and have just moved house. Looking to rewire and was looking at a few things, could someone tell me...
