Discuss What type of switch to use for outdoor lighting in the Lighting Forum area at ElectriciansForums.net
Lee B
I am looking to install lights in my garden. The cable will be run from the garage from the main fuse box. I want to be able to switch the lights on and off without having to go into the garage. I was thinking of maybe Bluetooth via mobile or a remote.
Can you give me some advise on the best way to do this.
Personally, I'd keep it simple and go with something like the Quinetic switches. Switch units with no battery send to a small receiver that will fit nicely inside a relatively small junction box such as a Wiska 308. I would also install a double pole isolator before it so when the outdoor lights start tripping the RCD you can fully isolate them until the problem is resolved.
thinkOP wants the switch outdoors.don't think quinetic are suitably IP rated. however, a remote receiver and a handheld fob might be a solution. then he can switch on even before braving the elements and oening his triple glazed multi-thousand pound bifold patio doors.
You can bind a single switch to any number of appropriate receivers, with each receiver being capable of listening to I think it's 10 switches.
They do fob style transmitters as well, so you could turn the lights on from the car for example. And I believe they do WiFi enabled versions which can be controlled via a mobile app as well as the switch modules.
I love the quinetic stuff...just avoid the dimming switch and controller as they are not 100% compatible with some loads yet, specifically some LED modular luminaires.
Fair play to the suppliers, when I told them of the problem they got on to the manufacturers and 'fessed up right away, offering to take back the kit and replace it with the standard stuff. So far, 100% success rate on that.
Reply to What type of switch to use for outdoor lighting in the Lighting Forum area at ElectriciansForums.net
Hi there I am getting someone in to change an outdoor switch and outdoor wall light (like for like). The old switch and light was covered by a...
Hi I've been planning to fit an outdoor junction box at the front of my house to hide a large brickwork hole and properly house the wiring...
can anyone please advise on where the wires go? My electrician installed a new cable ready for when I bought a security light. The cable as shown...
We have an outdoor socket that is hard wired into the ground floor power circuit and protected with an rcd in the consumer unit. I now plan to add...
hello all. I am trying to add led strip lights to my boat trailer. I have marine grade submersible lights. I will have them running parallel to...
