Discuss What will V1, V2, V3 and V4 in the example be? in the UK Electrical Forum area at ElectriciansForums.net
Hi every one
I have a problem which is very simple. I wanted to know what will the voltage on these four spots be. Amperage is not important for me and i don't think there are enough data to find the i1 and i2 on the circuit.
Thanks in advance for answering⚘
Why are there two batteries connected in opposition?
Is this a school question or is it something you're making at home?
It's a scientific question that has blurred my mind for years. I need to know what what happens to the voltage and the lamp. (specially if we omit the burning of wire because of overheating possiblities) what will the voltages in such cases be?
It's a scientific question that has blurred my mind for years. I need to know what what happens to the voltage and the lamp. (specially if we omit the burning of wire because of overheating possiblities) what will the voltages in such cases be?⚘
The lamp will light, assuming it is suitable for 12VDC. The second (40V) battery will overheat/discharge.
If you are taking R as 3 Ohms then you can use Ohm's law to calculate current flow in the left hand part of the circuit.
No current will flow from the second battery to the left hand side of the circuit because all current will flow down the short circuit (centre).
Yes, battery on RHS contributes nothing to LHS due to the perfect short circuit :)
Wow really? It's hard for me to accept that, cause according the kirchhoff 'slaw, at the upper part of the short circuit cable (cable in the middle) the electrons should flow in both left and right directions, and so i think the battery on the right should effect the lamp. ?‍♂️???
'The resistance in wires are not considerable' - so even though they are small they are not zero. Is that what you assume? If this is indeed what you assume then draw the circuit out showing the resistances of these wires and then do the mesh current analysis.
There is another assumption you have made without knowing it - or maybe you know it but have not stated it and are ignoring it - something about each of the batteries ;-) Again, include this in your circuit diagram and then do the mesh current analysis.
I think you confusion arises from assumptions you are making or not aware of.
My problem is not the resistance of the wires and they are ignorable for me (in real world it is less than 2 ohms for such a circuit if we do not assume the wires to be too long).
The batteries are as stated in the question. In such a question i have many more question marks about the direction and amount of flowing electrons, which is much more important for me.
So please get to the main point of the question and see if you can solve it.
With no switches I stand by my original post #3
..the 4V battery is now flat.
( The initial circuit has no steady state as the battery depletes ,So defies analysis.)-- Nor fuses if we are dealing with lead-acid etc.
If you are saying the resistance of the wires can be ignored, then the 40v battery on the right has a direct short circuit across it. It cannot affect the lamp.
Is that centre line meant to be a connection or just an indication of the values to its left? Its poorly drawn out - any cross connections should show the small filled in blob as on the arrows.
Ah that might explain things. Yes, not very clear if that is the intention.
Prince. I have drawn out and attached some of my explanation for you to study. You will note Kirchoff's current law is obeyed.
For the battery in Mesh M2 to influence the current Mesh 1 (and vice versa) the two meshes must share a branch - in this case resistor R where R is not zero.
When R is zero Ohms then the I bar junction in the middle collapses to a point as I have shown. A shared point between M1 and M2 obeys Kirchoffs current law but a shared point connection will not impress any of the electromotive force in Mesh 1 in M2 nor any of the electromotive force of M2 in M1.
You know that Kirchoff's Voltage states that the sum of the emfs in a mesh loop minus the voltage drops in that mesh loop equals zero. This equality for Mesh 1 includes (I1-I2) x R term as it also does for Mesh 2. If R is zero then this term becomes zero.
electromotive forces cause electrons to move to create currents. Thus there needs to be a shared branch of non-zero resistance for the 40V battery's emf to affect the current through the lamp.
It would be instructive for you to work out the mesh currents I1 and I2 for the circuit I have provided in the second attachment using general values R1, R2 and R3, V1 and V2 and assuming the wires are perfect conductors and the batteries have no internal resistance. Then do it for (R1, R2, R3) = (10,20,30) Ohms and (V1, V2) = (10,20)V; then do it again with R3=0 Ohms.
There is of course the case when R is infinite resistance ie: there is no middle branch - this collapses the circuit to one mess and the analysis becomes very easy.
Reply to What will V1, V2, V3 and V4 in the example be? in the UK Electrical Forum area at ElectriciansForums.net
Hello Everyone, I am building a new home in Illinois and will be running 400 amp service from the street where the main ComEd electrical line is...
Hello ! I am building for some time a cct to drive a 3digit multiplexed LCD. (from aliexpress) From the sellers on aliexpress I managed to find...
This is quite lengthy so get comfy... I had a bizarre call out relating to a job I attended about five years ago. The situation was they were...
I hope this is the right place to post this, please redirect me if not. I've spent quite some time reading the forums, so I apologize if I've...
Over the last few days, I have stumbled across a number of threads that seem to point to a prevalent misunderstanding. Either that, or I have been...
