Discuss What would happen if? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Dont quite agree with the resistances side of things. Obviously we are talking about impedence rather than resistance
And Xl = 2 Pi FL
the L is fixed for the coil, and the frequency hasnt changed. Therefore the Xl of the coil is the same, regardless of which V we apply to it. Obviously the I drawn will relate to the V applied, and the Xl of the coil will mean it will draw whatever I it needs. The coil MAY be able to handle this, it may not, depending on the VA rating of the tranny
It isnt 'automatically' going to blow!!!;)
This thread is over 3 years old, but just in case students or apprentice are reading this...
This is utter tosh, most transformers have two or more windings (unless it's an autotransformer), lets consider the case in question. One primary winding and one secondary winding, the impedance of the windings in this case are likely to be different, because the inductive reactance and the coil resistance are different for each winding as they are wound from wire of differing CSA and number of turns wound.
The insulation of both windings will be rated and flash tested appropriately for 230Vac namely at 2300Vdc. If the primary and secondary are swopped so the former 12Vac secondary is supplied as a 230Vac primary, the former 230Vac primary now tries to become a 4408Vac secondary but the winding insulation quickly fails destroying the winding and possibly the other winding and the former their both wound on, until the point where the circuit protection breaks the primary supply.
If the "transformer" (really a switched mode voltage converter) was of the type used often for ELV lighting and fans. With 230Vac applied to the former 12Vac output of the converter, the output circuit protection devices would fail instantaneously due to over-voltage, rendering the "transformer" dead scrap.
In theory 4370V. But the 12V winding impedance would be so low that you’ll be struggling to see through the smoke to read your meter.
simmilar happens when connecting a 12v halogen lamp to 230v. you can't see through the broken glass. maybe that's why manufacturers put a voltage rating on equipment.
I suspect that the electronic switchers would disconnect before anything serious happened. But a toroidal or double wound transformer would certainly give you a belt.
For continuous use you would need to limit the current flow through the primary winding to stop it from overheating and catching fire.
I heard that once a transformer catches alight, you then have to bury it in sand or fill the room with halon gas because you can't put it out. Mind you, I knew a woman once who could fill the room with a gas that could put you to sleep permanently.
Can confirm it doesn't last very long and does trip MCB, did it myself in a daft moment, the best bit was it was only accessible by a nice crawl through a gulley amongst some fibreglass. Needless to say I was pretty chuffed with myself :)
Reply to What would happen if? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi, I purchased a Time twin strand bell cable with a rating of 12-30V, 2A, low voltage, not for mains use. I wish to use this for installing our...
Hi I have a 3phase shop in a high humidity area in (Hawaii) and I'm having some issues with low voltage on the single phase outlets on the 120v...
Hello, I live in Mexico, where I have a small, un-official trailer park on my property. The property is serviced by my privately owned, 650amp...
Hello everyone. I'm in training but we haven't seen transformers or how they work yet. I have a transformer here I'm trying to figure out. There...
Just thought I'd share this quick sobering story that happened to me a couple of weekends ago.... Overhead 230v lighting festoon, LED golf ball...
