Discuss What would you advise here? in the UK Electrical Forum area at ElectriciansForums.net
Wirdy1
Hi, long time lurker, first time poster.
Friend has asked me to help him upgrade his garden outhouse wiring to make it safer. Without seeing the job I said that an 18th ed-complaint RCD garage consumer unit should do the trick.
However, I went round to the house tonight and had a quick look at his existing supply/fuse box. Omg, I think I'd want to rip it all out & upgrade everything before I put my name to any work on this system, but I know he won't want to spend money on that. Your thoughts? Would you walk away? Some of this stuff must belong in a museum??
2 main fuses? Is this a downstairs flat with a neighbour above?
You don't have to rip out and upgrade everything... Just the circuit you are working on.
Don’t touch anything unless the client wants it all ripping out and replacing
A full eicr would probably be my first port of call before making any alterations
Your pics seem to be centred on the service cable, head and cutouts. There's nothing much wrong with those that I can see, except for the BS951 earth clamp on the lead, which has obviously been there for decades but was never right. If the DNO provided an earth, they should maintain it correctly. If this was attached by someone else, and the DNO never provided a connection, that is a bit of a nuisance to sort out. I don't much like the connection feeding the other property but that's definitely someone else's problem. That could be used as leverage about the earth connection, as the two properties are connected to the same clamp.
On the customer's side I'm not seeing much in the way of MEB, and the Wylex boards should have their covers in place (which means no mixing of MCBs and BS3036s as they need different covers), and other various minor points but it could be worse.
It's an old mid-row cottage.
What I was thinking tbh.
Thanks for the comprehensive advice.
I have to be honest and say I was expecting to see the nasties (having read the thread tile)however,there seems to be very little that would be overly concerning
There are installations out there that seem to have issues far outweighing what is on view in the pictures provided
Reply to What would you advise here? in the UK Electrical Forum area at ElectriciansForums.net
Hi there, long time lurker, first time poster here. Straight down to it.. A friend asked me to add some sockets and additional lights to a small...
Hello, Would like some opinions. We have quite a few CU upgrades to complete. These are PRS properties, and looking down the list, a lot will be...
  • Locked
Hi, we need some advice on our scenario with regards to our rewire plan. I will get this out of the way first... We are planning to put the house...
5K
Hi there people. My name is Sym, I am 50 years old this year. When I left school in 1985 I started work with a local house bashing firm, I didn't...
B
Prefix - I've tried to post this in automotive, but it would not let me. This may be because I have not been recently active. Apologies if this is...
