P
prideofengland
Hi all
We have several test kits at work none of which perform very well under No Trip settings. I tend to use a Megger multi-function tester which works ok ish with the lead and plug top but which generally wont take a reading when using the seperate leads.
I normally have to calculate Zs based on R1+R2 but would prefer to get an actual reading.
With the increased use of RCD protected circuits finding things frustrating, so thinking of buying a seperate loop tester.
What would you guys recommend?
