CK Tools :) The professionals choice when it comes to Electrical Tools
Advertisement - Content continues below
Discuss What’s the going rates for the below instalation in the Electrical Forum area at ElectriciansForums.net
Hi just starting out working for my self after 10 years on the rail and I’m at a total loss at what the going rates are I don’t want to go in to high .I have been asked price up to Run a supply to a Bar in a garden, but due to the location of the distribution board in the house It would be easier to install a enclosure next to the meter And split the meter tails . The run is 35m to the bar so I was going to install a 6mm SWA cable protected by a 50amp 100m/a RCBO then install a 4 way DB with a 40amp 30m/a RCD mainswitch in the bar with a 20amp radial with 5 x double sockets 1 x lighting circuit. Any advice would be greatly appreciated
  • #3
Only reason I was going to install the 100m/a was to help with the discrimination from the 30m/a in the bar
TJ Anderson
Mentor
Why are you sizing cable for 50A capacity?? Ib for distribution circuit .....approx 22A
1. 20A for socket outlets as could be fully loaded so base on MCB,
2. Say.......2A for lighting
Protective device only needs to be equal or greater than design current ....
16mm for a 22A Ib 35M away.......No! :)
6mm is more than enough for CCC and VD. Zs for ADS you can work out as I don't know your Ze.
As already said don't RCD front end. 30mA Main Switch RCD in sub board. Put B40A on dist circuit as it is the highest you can go and will discriminate better with the B20 in sub board on SC'S.
  • #13
Hi TJ thanks
Aico Carbon Monoxide Detectors
Reply to What’s the going rates for the below instalation in the Electrical Forum area at ElectriciansForums.net
uHeat Banner - Forum Discount Available
Top Bottom
