Discuss What’s this black flooring? in the Commercial Electrical Advice area at ElectriciansForums.net
No necessarily electrical related but thought someone else might have come across this…
We are doing an office refurb and a couple of the sub floors are this black solid material ( was carpeted before), we need to sink some floor boxes in and run a channel across but don’t want to touch it without knowing what it is.
Can anyone help or point me somewhere where they may know?
For some reason my brain is telling me it's black phenolic ply.
It most likely isn't but nobody has had a better idea. :D
Any obvious joins?
Any obvious joins?
No, no joins. That’s the only reason I thought it wasn’t sheet material. It is a smooth surface though, isn’t phenolic ply textured?
once came across similar. there for 300 years. scraped off some of the 2" thick compound and the 12" thick floor which we thought was concrere turned out to be straw.
Depending on the age of the building, it could be a combined DPC and floor finish. Old council properties often had it as a way to level a rough concrete slab. It could also contain asbestos, so don't drill it if you are not sure!
Reply to What’s this black flooring? in the Commercial Electrical Advice area at ElectriciansForums.net
I am looking at installation of an architectural dimmer, that is will supply 6 channels, with 20A circuits each (2400W ea). Our hall has can light...
Hi all. Have an issue i'd love some advice on if anyone would be so kind. Will try to be brief. Thank you!! So, have an intermittent RCD trip at...
Before I pay an electrician to come check my work, I thought it worth a post here. I don't want to pay the cost of a small car for a whole-house...
