Discuss whats with all this volt drop crap? in the UK Electrical Forum area at ElectriciansForums.net
A
ayjay
posters on here often worry about volt drop, whats the prob with a few less volts @ the other end of the cable? will a few volts less end in disaster? will the suppy cable catch fire?
be nice i,m mellowed out at the moment:mickey:
Stuff dont work if volts are too low.
Despite everything we get told about supply voltage it is not 400/230V.
Most UK LV distribution transformers are:
11/.433/.250KV.
Tapings (if fitted) -5% / -2.5% / 0% / +2.5% / + 5% (set at 0%).
Reactance 0.45% up to 1000KVA, 0.5% above.
Voltage regulation is normally at the 33/11KV transformers with OLTC’s.
I tried lowering the LV voltage to 400V on 4 X 20MVA transformers as an experiment. Got nothing but complaints!
No pleasing some people!
There's an article on the TLC website showing how equipment designed for 230v which is actually running at 240v (still the norm) uses 6% more energy and has a much shorter lifespan than if it were to run at 230v.
So, if the Government is so keen to have us all reduce our energy consumption, why not force generators to adopt the 230v standard? 6% reduction instantly :)
My top floor lights flicker whenever I start the vacuum cleaner up, should I be worried?
you should be worried. vacuuming is a woman's job. can just see you as freddie mercury in the video . " i want to break free" PMSL.
Reply to whats with all this volt drop crap? in the UK Electrical Forum area at ElectriciansForums.net
Hi All, I have a client who is developing a plot of land for a single house. Currently, their 100 amp service cut-out is in a cubicle fed by...
Just thought I'd share this quick sobering story that happened to me a couple of weekends ago.... Overhead 230v lighting festoon, LED golf ball...
So a quick catch up so you can get an idea… I was asked to do a job for another electrician, as he is too busy. I’m busy myself but said I’d...
Over the last few days, I have stumbled across a number of threads that seem to point to a prevalent misunderstanding. Either that, or I have been...
Hello, I live in Mexico, where I have a small, un-official trailer park on my property. The property is serviced by my privately owned, 650amp...
