- Reaction score
- 2
The regs state that bonding should be made within 600mm of the services entry to the building, or after the meter. So for water, does this mean under the floor boards (ie generally under the front door) or where it appears above the floor boards?
Also just read a previous post where someone had commented that you shouldn't bond to an old lead pipe. Please can someone confirm if this is correct as I can't find it in the regs.
