Discuss Where to put the alarm. in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
B
billybob
Ive just fitted a split cu,both sides on rcd's.
My thought was,is there any way of diverting the alarm breaker off the rcd,as if it trips,the alarm my go off,while you're on holiday or something?
Or is there an accepted practice that I dont know of.
The exhisting board just had it wired to its own 3036 breaker.
Cheers,Kevin.
Cheers,Kevin.
You could fit a separate one way consumer unit,if you wanted.Whether or not it needs rcd protection itself would need to be verified.But I think if your new board had a non rcd main switch,your options would be easier.
your 2 rcds for the rest of the installation would still be fitted as well.
hager do a consumer unit guide to the 17th edd
I would think your new split CU can be arranged so that you can have 1 way that is not RCD protected. ie before your first RCD, the ones that i am familiar with have flexible bus bar arrangement eg wylex and MK sentry.
Reply to Where to put the alarm. in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
My friend just moved into a new build flat and its for a disabled person with a hydraulic lift to go to the upper floor. There was/is a leak...
Hi, just looking for advice. Ive been to look at a Fire alarm install job. While checking where i will take my supply from. 3 phase sub board, i...
What are peoples opinion's on this, pair of big old semi-detached houses (85 and 87) converted into apartments, dont think its a HMO although it...
So here is the thing Rhere is an old MEMSHIELD TPN+E Board that is pretty mich obsolete. The only place that sells their breakers would be Ebay...
