Discuss Where to start.. in the UK Electrical Forum area at ElectriciansForums.net
uk1403
Hi, I recently decided on a career move and am looking for any sound advice on getting the correct accreditation for becoming a qualified electrician domestic & commercial. I have no experience whatsoever and am thinking that i will be self-employed as I have Have owned various businesses in the past. I have good contacts in the property business and this could be advantageous. I’m really stuck on where to start. I’ve looked at different trainers access, logic etc..’is this really where I should start out? They seem really helpful and adamant this is where I should start. However I’ve read on some forums that I can get fully qualified through college nvq courses? Both are really expensive. Feel like I could be wasting time and money if I pick incorrectly. Really would appreciate any advice. I’m from Berkshire area so any suggestions on colleges training centres in proximity would really help.
2 schools of thought; condensed courses offer a wick turnaround allowing you to get out there quicker and get more experience whereas college will be 2 years to get to level 3, then you're looking at AM2/NQV3.
The advantage college has s that it takes longer, meaning you have of chance to get experience in, even if it's just as a mate to start.
Unless you choose a route that would give you experience and a full understanding of your subject, then starting from a point of zero knowledge and experience with a view to working for yourself would be a fruitless folly.
If you have no experience whatsoever, why do you think this career move is right for you? What is the attraction? You mention you have owned various businesses in the past - what has happened to them? Have you sold them as ongoing concerns? What sector were these businesses in?
Hi, my previous businesses were convenience stores, unfortunately I had to sell them to fund legal costs for my defence in crown court. I had an altercation on a night out 1 evening 7 yrs ago and ended up doing a 5 for sec 18. Whilst I was away I did a plumbing course and really enjoyed it. I did some research and spark's seem to be earning more than other tradesman, so I thought Id throw myself into it. I m just looking to for a secure career path, stability for family, options are really limited employability wise. Can you advise on the Landlord safety cert, what do they get charged at? the course provider was telling me theres good money in it
Don’t listen to the course provider.
Landlord safety certs or EICR electrical installation condition reports are not straight forward.
You need a lot of experience in the trade before you are competent to do them.
There are idiots out there doing them for £60 a time. I charge £150-£250 in domestic. The place is saturated with short course testers who haven’t a clue driving the price down.
Just completing the course isn’t enough.
Inexperience can cause owners to get work done that doesn’t need to be done and the opposite is true. You may not pick up on something that is potentially dangerous.
Get it wrong either way can be costly to the owner and you. There is an enormous amount of responsibility in doing them.
Having said that, I would definitely recommend the career. I love it.
Start with C&G level 2 and 3 electrical technology
18th edition
Test inspect course
Installation condition report course
Maybe the domestic installer course but only after completing the level 2 &3 C&G
More important than the qualifications is once you’ve got your level 2 C&G get in with a spark to learn the trade . Offer your services for free. Without on tools experience with a spark you will not progress and you can not get registered.
Expect at least 4- 5 years training. But it is worth it.
Good luck.
Plumbers round here charge £250 per day some as much as £350 per day , gas safe and that’s £450 per day.
What makes you think electrics will pay more ?
If you already have a plumbing qualification and some experience then I would stick to plumbing , fitting bathrooms etc
There are collages which are free took me two years of paying at night school whilst completing CG2365 level 2 , before I found a free collage ( or £10 a year) to completed CG 2365 level 3. Some people do the quick course. I still not qualified, but not too long now, I have needed the 3 years training and the volunteering with local sparks to improve my knowladge. Good luck, I love the job. (I am no spring chicken , wish I had started this when much younger).
Also completed the 18th and PAT , It all takes time and money, and a commitment.
Really?!?!
Have a bit of self respect. Money isn't everything.
i don't know. a good plumber who doesn't cut/burn cables, does not use your pre-drilled holes for his plastic pipes, does not fit a radiator in front of the socket you've just fitted, and does not test for a leak by spraying water on tour MFT, is hard to find.
I've corrected this for you, Tel :D
oxymoron
/ˌɒksɪˈmɔːrɒn/
noun
  1. a figure of speech in which apparently contradictory terms appear in conjunction (e.g. "a good plumber who doesn't cut/burn cables, does not use your pre-drilled holes for his plastic pipes, does not fit a radiator in front of the socket you've just fitted, and does not test for a leak by spraying water on your MFT"
There can be good money in it, if you have a landlord willing to pay for an honest and in depth report not just a piece of paper saying satisfactory. There are too many people running around doing them for under £100 and then hoping to get more work putting things right.
Also bear in mind there is likely to be another registration scheme in the next few years for these inspections so qualifications will be checked and may have other criteria to be allowed to do them. also likely a further cost. so may weed out a few cow boys.
I spent nearly a thousand pounds doing the 2391-52 its not an easy course if you have no experience or understanding of the regs/subject. this should be the very minimum before you consider doing them unless you have many years of experience.
Reply to Where to start.. in the UK Electrical Forum area at ElectriciansForums.net
Hello, I’ve started a modest handyman business and have come across some electrical obstacles. Up to now I have outsourced work to my electrician...
Hi everyone. I’m not sure I posted on the right thread. I’m a 22 year old trying to get into the industry the colleges around me don’t have...
Hello fellow sparks, I’m looking to do my testing and inspection course which starts on the 30th of April, but I have not got much testing...
Hi all, Customer has an extension and this compromises existing meter position, DNO is extending incomer and putting meter box on a different...
