Discuss Which board is subDB in this situation and which one is main in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
King84
Trainee
Hi everyone
quite new into the Inspection and testing world and still a learner and always strive to learn new things. I noticed in one property that tails coming from Meter into henley block which then feeds two consumer units.
My question is when you guys do EICR do you produce two separate EICRS for each board or just one schedule of inspection, one electrical installaion condition report and two Shedule of test results for each board?
The reason I am asking this is because I know when one board is fed from the main board, its called SubDB but in this situation both boards are fed from Henley block.
Reply to Which board is subDB in this situation and which one is main in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Been asked to move, remove and add some sockets the kitchen and I’ll need to add a circuit for an electric hob. Looked at the board and it’s one...
Hi, while carrying out an EICR at a farm cottage on Friday i came up against a problem early on. Whilst measuring the Ze the reading i obtained...
I have been asked to provide a quote for a supply to an toilet block on a campsite. The three phase supply to the campsite is approx. 150m from...
Cant get my head round this :( I understand N-E faults cause RCD's to trip, but I cant understand why on these 2 occasions, googled allover but...
