- Reaction score
- 51
Adding SWA from IP rated panel to IP box for WIFI, Minor works certificate for this? New switch in panel and socket in IP WiFi box
Discuss Which certificate??? in the UK Electrical Forum area at ElectriciansForums.net
Will be new circuit yesHave you added a new circuit
Electrical Installation Certificate thenWill be new circuit yes
New circuit then EICSo I’m adding a new RCBO and SWA from an existing Panel to a new outdoor IP box
Adding SWA should be the clincher clue here, Brad, .Adding SWA from IP rated panel to IP box for WIFI, Minor works certificate for this? New switch in panel and socket in IP WiFi box
Reply to Which certificate??? in the UK Electrical Forum area at ElectriciansForums.net
