Discuss Which certificate??? in the Electrical Forum area at ElectriciansForums.net
Adding SWA from IP rated panel to IP box for WIFI, Minor works certificate for this? New switch in panel and socket in IP WiFi box
Adding SWA should be the clincher clue here, Brad, .
Im adding a new RCBO and SWA from existing power bollard to new IP rated enclosure what certificate would you do? I think EIC but the bollard consists of 100amp main switch and 2x rcbos for sockets
Now on particular of instal at origin do I do the bollard? Or where the bollard is fed from eg panel?
Then distribution details I’m only adding power to a IP rated box?
Reply to Which certificate??? in the Electrical Forum area at ElectriciansForums.net
