Discuss Which Consumer Unit? in the UK Electrical Forum area at ElectriciansForums.net
Hi All.
Does anyone know of a dual Rcd metal clad consumer unit which has no knockouts at the top.
I’ve an existing one to replace and there will be around 10 20mm armoured glands coming out of the top of it.
Size of the consumer unit is not an issue as there is plenty of room and ideally neutral and earth connections will be at the top so no need to extend .
Cheers
Reply to Which Consumer Unit? in the UK Electrical Forum area at ElectriciansForums.net
I’ve always been alright with the knockouts provided for Fusebox consumer units but I’ve got a job coming up where I don’t want to use the large...
I live in a flat in Scotland supplied with an old 2 meter system called THTC where one meter using a time signal supplied heating and hot water...
I have a doorbell I want to install. The issue is the 16v transformer is designed to sit on a DIN rail. I have a 10 way 17th edition BG Nexus...
Hello, Is there an actual age limit on house wiring that would prevent a traditional fuse box being replaced with a consumer unit please...
