Discuss Which electric fan heater can be a in shower/wet room? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
vee
Is there such thing? The regulations assume a partition in the zoning. In this scenario the shower is a box room of about 1m by 2.5m with the shower in the far end and the loo and basin to the door. There was once a heater with the fused spur external in the hallway. Since then the shower now has been effectively turned into a wet room but the customer is elderly and feels the cold and there is no other heating in the room bar a small electric towel rail. What could I possibly fit?
What about those tubular heaters? Never used them before so dont know if they are any good or not, but seen some on TLC that are IP55. Follow advice above too of course.
Tubular heaters are used where they are providing heat to an area in the same manner as a central heating radiator.
A bathroom fan heater however, is only used for short periods of time, usually only for the duration of bathroom occupation. Hence the fan heater will have a much higher KW rating than the tubular space heating setup!!
If you use them for the potting shed or animal / chicken cot or garage workshop etc they are excellent
Reply to Which electric fan heater can be a in shower/wet room? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
i am wiring up a new en-suite: it is about 1.7m square, shower cubicle in one corner, toilet in other, door between, basin next to shower. I will...
I have been asked by Trading Standards to carry out a report on some electrical work installed by another company (5 years ago). The 'new' wet...
Hello All I am currently doing the electrics for an en-suite conversion to a wet-room for a family member. They want 6 no. 230Vac recessed...
Octopus
O
My wife wants a towel warmer in our small downstairs loo. The loo was once a small pantry. It is about the size of a telephone box, toilet in...
N
We have a shower room off our bedroom which was there when we bought the house. I think it was put in well as generally all the electrics and...
5K
NeilF
N
