Discuss which inverter? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
J
jsn999
Looking to put either:
1. 8 x 180 sharp on south and 8 x 180 west
2. 8 x 180 sharp in south and 6 x 180 west
which inverter can power the 2 scenarios
ta
I think an Aurora 3.0 has dual MPPT but I haven't checked that or the inoput voltages. have a look at the spec online. Gives you a start point anyway.
Reply to which inverter? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
We don't normally do PV, however I was called to a PV inverter with no power, 6 years old Found supply OK, however fed through a AC type RCD. PV...
Hello, My current 2.5kW Solar pv array is in a less than favourable position, but there is plenty of space to expand the array. I have an...
Hi world of knowledge I have two gen 1 x 5kw hybrid inverter, with batteries. My question is can I connect the two backup out put via 2 isolators...
A
the situation is this: 8 x 24v rgbw flood lights for a garden, each fitting has power consumption of 45w. 3 lights into a 200w driver, another 3...
I would like my plan checked by a professional. This project is a semi-open pavilion with a load center approximately 100 feet away. I am rating...
