Discuss which is the besst way? in the UK Electrical Forum area at ElectriciansForums.net
T
thekingiam
rewired all the house and forgot about light in pantry where consumer unit is.
would it be beter to run a cable from cu and put an extra mcb in, i have to put a socket in there as well from a 16 mcb so i could connect from the socket to a fcu into lighting circuit as well which would you do?
You don't need a whole new circuit. Also if you add a new circuit then it's notifiable.
Personally i would add another connection to the existing downstairs lighting MCB and run that to the pantry switch/light.
Run a spur from the consumer unit's downstairs socket mcb to power the socket.
as above^^^ K.I.S.S. , as my old boss used to say.. "keep it simple, stupid."
i was thinking of running a cable to existing lighting mcb but was thinking of segregation of circuits. i suppose it makes no difference as the mcb controls lights,what about when i come to test would i group it with all lights on that mcb?
if i connected the socket to the 32 amp ring main mcb when i come to test would i use this spur to get my readings for R1 and R2.
I guess you used the loop in system with feeds going to the rose. Pull the feed out of the CU take it to the new position and install a new length of cable back to the CU, and a switch wire.
I would have thought better to come off the upstairs lighting circuit, at least then you would have light in the pantry to see what you are doing at the CU, if the downstairs lighting breaker tripped.. lol!!!
good point, eng. and as steveberry says. just make it the first light on the existing circiut .
I think the best design is to have it on the main switch (no RCD protection) with the switch drop in mini trunking.
For obvious reasons.
only if he's got a hi integrity board, though.
wouldn't want to pull back cable as i have had difficulty getting all cables to cu as it is .
as you can see not much space to drop cables. lighting cables in 25 mm trunking on the right and i need them on the left, running a new circuit from cu would save me alot of sress and effort, would i need a seperate mcb for 1 light or connect to existing mcb in cu?
TBH mate it really doesn't matter what you do. The most important thing is that you do whatever is quickest and easiest so you can get yer feet up earlier.
You can use the feed as a draw to pull the new cable in and a new mini trunking for the switch drop (easy) or divert the supply out the side of the trunking and fit a wall mounted bulkhead.
if its that tight would it not be better to fit a length or 2x2 trunking in place of those 3 lengths
Have you taken into account the grouping factor for those cables?
No.
You need to check the R1 and R2 on this spur, but this spur will be short, so will give untypically low figures for R1+R2. You need to record the highest R1+R2 for the circuit, which will be somewhere near the middle if it's a ring, or at the extreme end if a radial, or possibly at the end of a long spur off the ring.
could non rcd protect in mini trunkiing, but tt system so main rcd usually trips out everything first before split load rcd s in cu.
Which says to me that the "main" RCD is not time delayed. Are you intending to remove or replace it when you've finished wiring the CU? (I assume that all final circuits are protected by RCDs in the CU.)
Reply to which is the besst way? in the UK Electrical Forum area at ElectriciansForums.net
Hi guys, I have supplied my Shed with a 6mm SWA cable into a nice consumer unit. In there I have a 6Amp MCB for the lights and a 16 A supplying a...
Hi. I'm in the process of getting my qualifications and am taking on some small jobs for family to try and get some experience in. Today I was...
Hi, just helping someone out and apologies for the long winded post. Would like install a couple of weatherproof double sockets on the patio. 1...
Hi guys, newbie posting! Does the following sound ok... Existing circuit: SOCKET on a ring -> spur to SWITCHED 3A FCU -> SWITCH -> hardwired FAN...
Hi all, Curious one and hopefully some one of you could give me some advice. A customer has had a steeltech shed installed at their premises. A...
