- Reaction score
- 5,578
I have a customer who wishes to have LED tape under the wall cabinets. I always fit 230V strip lights rather than tape as there is less to go wrong as no LED drivers involved. he would actually be ok with strip lights but has specified 2700K and I can only find tape in this rather than 230V strip lights. Anyone know where I can get some and therefore avoid the following...
I have not fitted tape before. I will be using a constant voltage LED driver as the lights will be in parallel. In total there will be perhaps 100w of tape. The diagram shows only 3 tapes, but in reality it will will cut into 6 or 7 bits from one strip.
My question is, is either of the following acceptable and which is best?
Is this just the same as if you were fitting MR16's downlights where each would usually have there own transformer? I would have thought it better to fit individual LED drivers as you will have a long run of cable which the 24V driver will have to deal with and VD may come into play, whereas with individual drivers they will be much closer to the light. Plus if the 100w driver fails all lights fail instead of just one. But, is this ok with each section of cut strip or do they have to have the same power supply?
