Discuss Which power source can I run a cable from to connect a bathroom mirror/light? in the Lighting Forum area at ElectriciansForums.net
Fraggle
DIY: hi I’m looking for advice on how to connect an led bathroom mirror/light unit to a power source. I have a pull cord light switch and a fan switch in the bathroom and a light switch outside the bathroom that’s connected to a light switch at the foot of the stairs. Basically what I want to know is can a power cable be run from one of these switches to the mirror/light.
Many thanks
first, has the new light got it's own on/off switch? if so, you need just a L,N,and E to it. this would usually come from the light fitting, but sometimes you'll have a N at a switch. has to be seen to evaluate properly. I recommend getting a local electrician in. cost is minimal.
Thanks for your reply! As far as I know their is a switch on the mirror for the light I’ll have to check to be sure. If I connect a wire from the light fitting to the mirror will the mirror light still switch on with the bathroom light switch at the off position
all depends if you have a permanent L at the light.
brown to brown, blue to bits, springs into mind. electrician requred before fire.
My house Is relatively new built ten years ago and in that time a few of my fused sockets one for tumble dryer and 1 for fridge have been giving of a fish smell. Wondered for months what the smell wz then realised the socket wz warm and wen I took the socket apart the blue wire wz frazzled what do u think caused that. Wasn’t me as the tumble dryer and fridge just got plugged in from the plug running from fused switch.
cheap sockets and/or poor termination of conductors (not tightened down properly).
Reply to Which power source can I run a cable from to connect a bathroom mirror/light? in the Lighting Forum area at ElectriciansForums.net
I’m sure this is simple, but it’s confusing me for some reason. I have a line wire coming into a bathroom that used to go to a lighted medicine...
Hi, have an old bathroom fan. Which has two wires the black and red (line and neutral). The fan has no isolator switch and was powered when the...
Hi all, I'm wondering if someone can answer this question concerning a wiring scenario. I recently saw on a youtube video - a guy create a...
DIY query Have narrowed down the source of an occasional trip to one light circuit which is a varilight v-pro master dimmer slave set up. This...
