Discuss Which surge protector. in the Electrical Engineering Chat area at ElectriciansForums.net
I know about type 1 and type 2 surge protectors,and which one to use.
But what criteria dictates the rated amperage of the device.
Are there any parameters to consider, other than the load I am trying to protect.
Information on these devices is hard to come by.
Any help appreciated. Thanks
Surge Devices are very helpful. Suggest giving them a call (after the holiday?). Can buy direct or through CEF.
[automerge]1577136297[/automerge]
[automerge]1577136686[/automerge]
[automerge]1577137461[/automerge]
Dehn have a lot of info under the Download section here.
[automerge]1577137549[/automerge]
  • SY123-2.pdf
  • Guide to Surge Protection.pdf
  • Surge_Brochure_2017_Low_Resolution.pdf
Reply to Which surge protector. in the Electrical Engineering Chat area at ElectriciansForums.net
Hi guys, could someone help with the following please? The scenario is: Domestic property supplied via three phase (with a 3P main DB, NO SPD)...
Hi all, Hoping someone can shed some light on this, i have purchased a surge protector and it will not fit the power cables i plan on using. I...
Hi, I have recently had 18 solar panels (390W) fitted to my roof. The system is a GivEnergy. A Gen 1 Hybrid 5kW inverter (Gen2 version could not...
Hi all, what is the best way to configure surge protection in domestic dwellings when you have multiple consumer units? Does each consumer unit...
4K
