B
bowhillgrove
if you have a sub main to upstairs flat should you record the Ze at the incomer mains or the comsuner unit in the flat?
Discuss which Ze result should you record in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
but not the Zs for the final circuits fed from the sub-main.
no , that would be insane !!
;-D
Is there a box on the test sheet for recording "insane" ??
Reply to which Ze result should you record in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
