Discuss Whining noise from multiple sockets ? in the UK Electrical Forum area at ElectriciansForums.net
LewisM
Hello, I fitted some extra sockets in a bedroom two years ago, and the customer has said that 2 of the sockets make a high pitched whining noise, all tested at the time readings fine etc, I've attached a video, doesn't sound like arcing to me as it's not a crackling sound? I've told them not to use the sockets for now until I can have a look on Sunday, I can't see how two sockets could have gone faulty any ideas?
Well went there today, everything tested fine ZS wise L-N L-PE however voltage was 251V, the charger wasn't making the noise when I was there (as usual), they said it happens more at night, I've left my fluke there and told them to plug it in when the charger makes the noise and send me a picture of the voltage.
Mate that's the plug itself that they have plugged in. Them cheap things always start whining after a while. My phone charger is always doing it.
Also it might whine once the phone is charged and the load drops, so only later on or unplugged.
A lot of switching converters can vary the mark:space duty cycle to regulate the power over a moderate range and switch in the 100kHz or more range so are inadudible, but when the load drops down they can't reduce the "on" time enough so start to operate in a burst mode and that might put the burst rate in to the human hearing range.
Reply to Whining noise from multiple sockets ? in the UK Electrical Forum area at ElectriciansForums.net
Hello all, Looking for help here as I've come across a strange call-out today. Bare with me here: Got a call from a customer saying they had...
Hi all, For clarity, I'm not a qualified electrician, but have a reasonable amount of experience as I've done plenty of wiring (signed off by a...
Hi all, Was speaking to a family member recently, he told me his iron recently made a bang and flash as he plugged it in to the socket, and could...
Hello there, we are wanting two new double sockets in our kitchen, one will be below counter to accommodate gas hob and ovens ignition plugs...
