Discuss White accessories only for dual backbox? in the DIY Electrical Advice area at ElectriciansForums.net
Deleted member 112675
Hello All
Firstly, apologies for two threads almost at the same time - I promise this will be my last question for a little while!
So I don't understand what is the reason or the reg for not allowing metal sockets on a dual, metal, flush backbox? Would it be a C2 or C3 (assuming both are on the same circuit/mcb)?
I am also wondering.
Can’t think of a reason why you can’t do it.
Can’t think of a reg that mentions it.
Why do you think it should not be done?
Thanks for quick reply James.
IF you look here it says "white accessories only".
Is it maybe because not all metal ones would physically fit? The ones I have do fit hence why I'm wondering if I can do it or not.
Most metal decorative accessories are wider that standard white ones, and it will often be impossible to fix two metal ones side by side in a dual 1G box.
Instead, you can put two single boxes side by side with enough of a gap that any faceplate will fit.
Yes. Purely down to the physical size of metal or other decorative faceplates.
Well maybe I got a bit lucky as I'd already bought everything from the bg nexus line and the plates seem to fit ! I'm glad I checked there wasn't any electrical reason for it though. Thanks a lot for your time.
Reply to White accessories only for dual backbox? in the DIY Electrical Advice area at ElectriciansForums.net
  • Locked
5K
Hi, I have a dual RCD board made by Hager installed a couple of months ago. It is high integrity, which I understand to mean RCBO’s can be...
I posted last week regarding a lighting cable being too short in the wall to reach my new light fittings.this is still annoying me lol, I will try...
Morning all So the site I'm based at recently had some work done (think partitioners). This package of work included electrical. This was...
8K
Good Morning everyone. Quick question regarding a sub main from a TNCS supply feeding an outbuilding on TT. This is a domestic installation not...
